HJR-Holland
Do Jul 17, 2003 19:00
Dordrecht
Q & A kwaliteitsissues LEGO
door HJR-Holland » Zo Dec 19, 2010 10:21
Hallo allemaal,
Onderstaand de eerste van (hopelijk niet al teveel) de kwaliteitsrapporten van LEGO. Doe er uw voordeel mee!
QUALITY ISSUES & COMPLAINTS FROM LEGO FANS
1. Instruction booklets come loose in the boxes. They sometimes get damaged during transit. If they were tightly packed in polybags, it could prevent such damages. Stickers also get wrinkled, they could be packed with instructions.
a. Yes we know and we have started to package building instructions, labels and textiles in all sets with more than 1000 prices in a poly bag. The current solution is a quick and dirty one. Version 2 will be ready with-in the first 3 month of 2011.
2. Fans are having hard time choosing colors from instruction booklets. Black and dark grey are especially very hard to distinguish.
a. It is not only fans that have the issue. All of us have. The last 4 years we have tried to optimize this 2 or 3 times by adjusting the printing technique with no luck. For 2012 second half products we will introduce an out-line for black elements – cross fingers that it will help.
3. Injection marks on transparent parts are ugly, fans don't find them suitable for building. Especially window/glass pieces require more attention about molding.
a. There have been made some changes but give us an overview of the elements and we can verify/show if they have been corrected
4. Slopes come with different surface textures. Some are completely smooth while others have grain on them. It would be better if they were standardized.
a. 2 - 3 years ago we ensured that all roof tails’ have the same surface. By an unknown reason back in 2003 the surface of roof tails was changed from rough to smooth. All set manufactured the last 2 years should have uniform roof tails
5. Studs on certain parts are sometimes solid and sometimes hollow. This should be standardized too.
a. Sorry no. A hollow stud are there either because we need that building function (a tool for the minifigure fits on to the hole) or because we for technical reasons cannot make the stud hollow from the back. Look at the studs from the back on a plate. The studs is hollow otherwise we cannot control the dimensions.
6. Small tires are covered with some greasy material. Dust sticks on them and it's hard to clean it.
a. We need the grease in order to remove the part from the mould. Yes it tend to be sticky and we are constantly trying to improve the materials used for tiers as they give other technically challenges.
7. There is a major tone difference in same colors. Dark red, red and yellow are the most troublesome colors about this issue.
a. We are constantly improving our coolers and many improvements have been made the last 3 – 4 years. Please judge the current quality based on set packaged the last 6 months and feedback on that as we want the right quality.
8. Some pieces are translucent, especially red ones. They look too bright next to other parts in same color.
9. Figure heads or torsos are problematic. Some heads don't fit on some torsos, they stay too loose.
a. We need some examples, and please do so in order for us to correct the moulds.
Omdat op het ambassadorsforum nu een kwaliteitstopic is geplaatst waar een ieder zijn/haar klachten kan plaatsen en waar nu ook zeker is dat er door de kwaliteitsmensen van LEGO wordt gekeken, zou ik aanraden jullie klachten / opmerkingen in dit forum te plaatsen, zodat ik het door kan loodsen naar LEGO. Jullie imput in punt 9 zou ook welkom zijn.
MVG,
HJR
my FLICKR account
Re: Q & A kwaliteitsissues LEGO
door Duq » Zo Dec 19, 2010 11:54
Volgens mij is het aantal onderdelen niet zo belangrijk. Ik heb de indruk dat het vooral sets zijn waar een paar grote onderdelen niet in zakjes zitten, zoals bijvoorbeeld de goederentrein, waar train-bases en rails niet in zakjes verpakt zijn. Volgens mij richt dat de meeste schade aan aan boekjes.
door aawsum » Zo Dec 19, 2010 12:06
Wat wordt hiermee bedoeld, een omlijning waar het zwart betreft ?
En over punt 9, kunnen we daar aan toevoegen hoe slecht minifigs tegenwoordig op stoeltjes blijven zitten.
door JunkstyleGio » Zo Dec 19, 2010 12:13
Misschien krijgen de zwarte onderdelen wel een witte (of lichtgrijze) tekenlijn in de bouwbeschrijvingen?
door LegoHenkie » Zo Dec 19, 2010 12:52
JunkstyleGio schreef:Misschien krijgen de zwarte onderdelen wel een witte (of lichtgrijze) tekenlijn in de bouwbeschrijvingen?
Daar was twee jaar geleden ook al sprake van.
Heeft hier op het forum al een voorbeeld van gestaan.
Als ik mij goed herinner, geplaatst door Rusty.
legomannetje
Vr Okt 24, 2003 9:08
Highland
door legomannetje » Zo Dec 19, 2010 18:30
Voor een aantal onderdelen, zoals technic pins is dat al geruime tijd het geval. Omdat andere zwarte onderdelen dat niet hebben (hadden) lijkt een zwarte beam met zwarte pins in het boekje al snel een donkergrijze beam met zwarte pins.
Overigens was het wit omkaderen van zwarte stenen in de tijd van de handgetekende boekjes standaard. En toen was er nog geen eens donkergrijs om mee te verwarren. Toen was de reden ook meer om de vorm van de zwarte stenen duidelijk te maken, omdat zwart in de boekjes ook echt zwart was en met zwarte lijntjes zie je de vorm dan niet meer.
Neanderthaler
Za Okt 18, 2008 20:29
Montfoort
door Neanderthaler » Ma Dec 20, 2010 8:52
Weet iemand misschien waarom tegenwoordig zo veel gebruik wordt gemaakt van stickers ipv. bedrukte steentjes? Is dit een ordinaire centenkwestie?
door stuifzand » Ma Dec 20, 2010 9:19
Dat is een vraag voor in het algemene topic, niet voor het centrale topic voor de Q&A met LEGO over kwaliteitsissues. Graag daar nog een keer stellen.
door Duq » Ma Dec 20, 2010 10:30
Dus:
in plaats van:
door eti » Ma Dec 20, 2010 11:43
Duq, je post doet het niet. Althans ik zie in plaats van je bovenste plaatje alleen maar met koeieletters 'Cookies must be enabled' staan.
door LegoHenkie » Ma Dec 20, 2010 12:40
Bij mij wel, het is een png plaatje
door eti » Ma Dec 20, 2010 13:47
Hier ook, maar de inhoud van het plaatje is alleen die letters. Misschien ligt het aan IE hier op het werk.
door WvdP » Ma Dec 20, 2010 13:49
Of aan de cookies. Ik heb het op mijn werk met zowel FF als met IE...
Luc2000
Ma Jul 20, 2009 12:09
Zuid-Limburg
door Luc2000 » Ma Dec 20, 2010 13:51
Doen ze het nu wel?
Imagine - Build - Play
Brickshelf en Flickr
door WvdP » Ma Dec 20, 2010 14:59
Nu wel, dank!
door LegoRK » Ma Dec 20, 2010 16:36
Ik heb heel vaak na een tijd dat onderdeeltjes inscheuren, vooral cheeseslopes en bricks 1x1 (ook modified). Ik heb al een paar keer nieuwe gevraagd en een keer een mail naar Lego gedaan. Door de prima service vervangende onderdelen gekregen. Maar helaas blijf ik ingescheurde onderdelen zien...
HJR-Holland
Dordrecht
door HJR-Holland » Ma Dec 20, 2010 19:42
LegoRK schreef:Ik heb heel vaak na een tijd dat onderdeeltjes inscheuren, vooral cheeseslopes en bricks 1x1 (ook modified). Ik heb al een paar keer nieuwe gevraagd en een keer een mail naar Lego gedaan. Door de prima service vervangende onderdelen gekregen. Maar helaas blijf ik ingescheurde onderdelen zien...
Hi,
Als je nu even artikelnummers en/of afbeeldingen hebt zou dat bijzonder welkom zijn :)
my FLICKR account
door MOCkingBird » Ma Dec 20, 2010 20:16
Hier een voorbeeld van cheeseslopes (50746) die snel scheurden
door Rusty » Vr Dec 24, 2010 23:27
Inscheuren heb ik ook met diverse onderdelen, vooral als ze 1 nop breed zijn, dus plates 1 x 2 aan de korte zijde, bricks 1 x 1, tiles 1 x 1 etc. Soms na slechts een paar weken in elkaar gebouwd te zijn. Ik heb sets die al bijna zo lang als ik leef in elkaar zitten, en die zijn nog "scheurvrij".
Kromme assen, vooral de langere. Het gaat de laatste tijd beter, ik kom geen kromme 5L meer tegen bijvoorbeeld, maar bij 7L en langer gaat het nog wel eens mis, en slingeren de assen nogal. Als een as dan door een aantal gaten moet, wringt het wel eens. Een betere uitzoeken, en het is weer goed, als er tenminste een betere in je set zit.
Scheve onderdelen. Bijvoorbeeld plates 1 x 2 waarvan de noppen niet in het midden zitten. Druk je er 10 op elkaar, dan heb je een flauw trappetje wat schuin naar boven gaat, ipv recht. Komt ook bij andere plates voor, vooral 1 x 6 zag ik de laatste tijd vaak.
door LegoRK » Ma Dec 27, 2010 14:33
Hier komt 'ie dan, het is wel in de loop van ongeveer twee en half jaar.
ingescheurde steentjes:
300528 brick 1x1
4113261 brick 1x2x2
4211180 palisade brick 1x2
306901 flat tile 1x2
4558952 brick 1x1 w. 1 knob
4546705 roof tile 1x1x2/3, abs
4211349 brick corner 1x2x2
4504379 roof tile 1x1x2/3, abs
4544215 cow assembled "no.1" (gespleten kop)
element met krassen of gietfout of iets dergelijks:
4541890 column 2x2x11
4519682 dwarf, helmet, king, drum laqu
4211240 fabuland broom
4211007 mini pickaxe
4541951 wall element 3x3x6 1/4 bow
konden niet recht geplaatst worden:
4190511 left door 1x3
4537985 right door 1x3
*bovenstaande tekst is uitsluitend bedoeld voor op dit forum (Lowlug), met uitzondering van de Lego(R)ambasadeur.*
door JunkstyleGio » Ma Dec 27, 2010 15:47
Voor het eerst sinds tijden (5 of 6 nieuwe sets...) weer een probleempje gehad.
Van de 6 32278 in de 8069 waren er twee in citroengeel i pv het normale geel.
Het valt overigens niet op in het model zelf.
Ik zal het morgen melden aan de klantenservice.
door LegoRK » Wo Dec 29, 2010 20:50
Nog iets van deze week:
2 kromme plates, licht grijs, 6x10.
-ik heb net bij Lego nieuwe gevraagd-
Jasper Joppe Geers
Vr Okt 30, 2009 23:59
Schijndel
door Jasper Joppe Geers » Za Jan 01, 2011 20:15
Ik moet zeggen dat de bouwinstructies inderdaad wel wat
verbetering kunnen gebruiken. Ik denk wel dat het niet zozeer
te maken heeft met de manier van drukken maar meer de kleurprofielen
van de computer die de te drukken bestanden genereert.
Het zwart is wellicht een probleem, maar de onderlinge verhoudingen
als het gaat om de grijstinten zouden wat beter aangepast kunnen worden.
het verschil tussen donkergroen en donkerblauw en zwart ligt voor de
meeste mensen gewoon te dicht bij elkaar.
Ook het soort papier wat gebruikt wordt zou beter kunnen. Ik snap
dat er wordt gekozen voor een 'glossy' papiertje, maar door mat
papier te kiezen heb je veel minder last van een hinderlijke weerspiegeling.
Laten we hopen op beter!
groetjes,
JJ.
door Duq » Wo Jan 05, 2011 13:38
Ik heb al wel vaker ingescheurde armpjes gezien maar hier is de torso ook op twee plaatsen gescheurd:
HJR-Holland
Dordrecht
door HJR-Holland » Do Jan 20, 2011 22:15
Hallo allemaal,
Ik heb de issue van de scheuren vandaag voorgelegs aan de QM van LEGO :duim:
my FLICKR account
Edgar
Zo Mei 10, 2009 18:20
Hardinxveld-Giessendam
door Edgar » Do Feb 03, 2011 13:29
Afgelopen weekend de 8043 gekocht. De bouwbeschrijvingen zaten in een zakje met daarin ook een stuk karton zodat de beschrijvingen niet konden vouwen. Goede actie dus! :duim:
door legOscar » Vr Feb 04, 2011 20:31
Ik heb de 8043 voor mijn verjaardag gehad, maar daarbij was dit nog niet het geval. Een boekje zag er aardig verfomfaaid uit. Ik denk dat ik dus een oude versie heb met ook de oude LA's, want hij lijkt ook aardig moeite te hebben met het liften van de giek. Belletje naar LEGO dan maar...
door aawsum » Vr Feb 04, 2011 21:21
Ingescheurd uit de set 8404 (maand of 2 oud)
2 keer de slope 1x1x2/3
1 keer de slope 1x2x2/3
door Rusty » Zo Feb 06, 2011 22:44
Bij plates 1 x 6 is een onzuivere mal (onderdeel niet symmetrisch, dus "trappetjeseffect" bij stapelen van deze onderdelen) in omloop. De goede hebben de gietpunt op de 3e nop van de zijkant en 37 - 12 onderop gedrukt. De slechte hebben de gietpunt op de 1 na laatste nop van de rand, en bijv 8 2 5 onderop als malnummer/productie batch nummer. De nieuwste set waar dit onderdeel in zat (de rode mini technic container truck) had weer de goede, maar ik weet niet of dit meer oude voorraad was, of een teken dat de nieuwere plates weer goed zijn.
HJR-Holland
Dordrecht
door HJR-Holland » Do Feb 10, 2011 18:42
Thu Jan 20, 2011 22:15:
HJR schreef:Hallo allemaal,
Ik heb de issue van de scheuren vandaag voorgelegd aan de QM van LEGO :duim:
En ik kreeg nog antwoord ook:
Hi HJR,
If you ask the engineers and material specialist in TLG they will say that 1X something bricks was invented by the devil due to difficulties in ensuring that they do not crack
When the plastic is injected in to the mould cavity the melt front tend to cool a little. On 1X something bricks two melt fronts meet at the end of the brick. At the attached picture you see very clearly on a brick where the melt fronts meets. It is the scratch like marks. the brick is weaker at this point and if the melt have been slightly to cool the brick becomes to weak. It can happen during start-up or if the machine have been stopped for some reason. When the brick is build tension is right at that weak line for 1X something bricks and if some "finger grease" is then apply the element might break.
It is a problem we always have had and if I look at my old LEGO collection that is 25 - 30 years old I can find many elements that are broken. It is normally not possible to se until you build with the element.
I hope this explain the technically reason behind.
Et v'la, uw antwoord. 1x __ onderdelen komen van de duivel...
my FLICKR account
door Rusty » Do Feb 10, 2011 18:53
Ik wil geloven dat 1 x ? bricks en 1 x ? plates sneller inscheuren, maar ik heb in een een handvol recente Creator sets al bijna meer ingescheurde onderdelen dan in de rest van mijn collectie. Zelfs stokoude sets als de 918 die al jaren in elkaar zitten, hebben geen probleem. En je ziet de scheuren niet alleen op de smalle kant, ik kom ze ook tegen in de lange kant van 1 x 4 of 1 x 2 bricks, waar het "melt-front" niet zit. Dat zit immers op de smalle kant, zo zegt die uitleg. Dus het heeft naar mijn idee ook met het materiaal te maken. Is de wand-dikte van diverse onderdelen niet minder geworden de laatste tijd om plastic te besparen?
door LegoHenkie » Do Feb 10, 2011 18:57
Wie vertaalt effe dit Lego stukje, want ik snap er nix van.
door TAFOL » Do Feb 10, 2011 19:20
Ik heb even mijn talenknobbel erbij gepakt en daaruit kwam het volgende stukje:
Hoi HJR,
Als je het de ontwerpers en materiaaldeskundigen bij TLG zou vragen, zouden zij zeggen dat 1x iets stenen door de duivel zijn uitgevonden doordat deze stenen makkelijker inscheuren.
Wanneer het plastic in de mal wordt gegoten, neigt de voorkant ietsje af te gaan koelen. Op 1x iets stenen zit deze voorkant bij het eind van de steen. Op de bijgevoegde foto kun je duidelijk zien waar de voorkant zich bevindt. Het zijn namelijk de krassen op het steentje. Het element is zwakker op dit punt en als het smeltsel afkoelt, wordt het steentje te zwak. Dit kan gebeuren wanneer de machine opgestart wordt of als deze door 1 of andere reden gestopt is. Wanneer het steentje ergens op gebouwd wordt, komt er druk op de voorkant en vooral als er hard op wordt gedrukt, kan het steentje mogelijk breken.
Het is een probleem die wij altijd al hebben gehad en wanneer ik kijk naar mijn oude LEGO-collectie van 25-30 jaar oud, dan kan ik veel steentjes vinden die zijn gebroken. Het is normaal niet mogelijk tenzij er mee gebouwd wordt.
Ik hoop dat ik de technische kant hiervan duidelijk heb uitgelegd.
door dip » Do Feb 10, 2011 20:42
plus punten voor die vertaling Tafol (en vooral het leesbaar maken). Niet dat ik geen engels kan, maar de originele zinnen lopen toch niet echt lekker.
door LegoRK » Do Feb 10, 2011 21:31
Tof dat je antwoord hebt gekregen, maar ik vind het enorme onzin. Wat eerder ook gezegd werd: ik heb veel oude lego, maar nooit een scheurtje gezien (maximaal 1 misschien). Nu ik de laatste jaren nieuwe sets koop: altijd vertonen ze na een paar weken of soms maanden scheuren. Dan moet het wel heeeeel toevallig zijn dat ik net steeds de legodozen met 'duivelstenen' heb.
BramAkkermans
Do Jan 29, 2009 19:37
door BramAkkermans » Vr Feb 11, 2011 0:07
Hi HJR,
....... At the attached picture you see very clearly on a brick where the melt fronts meets......
Heel Nieuwsgierig, zou je de foto misschien willen posten ? :oops: :P
Be As You Are
Mijn Brickshelf - in de meivakantie komen de foto's !
door Rusty » Vr Feb 11, 2011 15:19
Ik ben ook wel benieuwd naar die foto. En is er dan geen manier om dat melt-front te verplaatsen naar een plek waar het minder stress te verduren heeft? Dit klinkt nu een beetje als een paar hechtingen plaatsen op een plek waarvan je weet dat er continue spanning op kan staan, en dan is het niet raar dat ze los schieten.
Wat me wel opvalt is dat bij veel oudere onderdelen het gietpuntje aan de zijkant zat. Wel minder mooi, maar als je onderdelen daardoor minder of niet meer inscheuren (wat ook niet bepaald fraai oogt) zou dat misschien een optie kunnen zijn. Ik kan me niet voorstellen dat het technisch onmogelijk is dit probleem aan te pakken, ik heb sets die tientallen jaren in elkaar zitten, waar nog geen scheurtje te bekennen is, terwijl bijna elke recente set die ik heb wel minimaal een paar ingescheurde blokjes heeft, zelfs na een paar weken of korter opgebouwd staan... En zoals eerder opgemerkt, niet alleen in 1 nops brede elementen, maar ook gewoon in de lange zijkant van een brick 1 x 4, of een plate 2 x 6, dan weer de korte kant. Als ze bij Lego denken dat het exclusief een probleem is van 1 nops brede onderdelen, kan ik ze wel een paar voorbeelden bezorgen...
door Aliencat » Za Feb 12, 2011 9:51
Dit is de foto die hij bijgevoegd had aan het bericht dat HJR citeerde:
BramAkkermans
door BramAkkermans » Za Feb 12, 2011 10:43
Ik herken het onderdeel niet :oops:
Dat is toch geen standaard cheeseslope of 1x1 steen (?)
Be As You Are
door Aliencat » Za Feb 12, 2011 11:21
Dat is een slope 45 1x2, vanaf de zijkant gezien.
In het stukje dat HJR citeert zie ik trouwens ook nergens een 1x1 steen of cheese slope genoemd, alleen "1 x iets onderdelen"
